PEEK J-head long-distance
Advantages
- Internally, the filament path is identical to that of an already proven design.
- The design is simple as the number of custom machined parts is kept to a minimum.
- If necessary, the PTFE liner can be replaced by using an off-the-shelf piece of PTFE tubing.
- The PTFE is not stressed nor used to provide support. This reduces a point of failure that is part of other designs.
- A resistor is used as a heater. There is no need to wrap nichrome wire or to bake a heater core.
- Heat transmission is improved as there is no thermal junction where a separate heater screws onto the nozzle.
Product Introduction
| Molding form | FDM |
| Material | PEEK |
| Movement speed | 50cc |
| Outline dimensions | 18*65*15mm L/H/W |
| Weight | 50g |
Click here to buy:
http://www.geeetech.com/assembled-jhead-hot-end-longdistance-p-792.html
http://www.geeetech.com/peek-longdistance-jhead-hot-end-p-801.html
