Melzi V2.0
Revision as of 03:49, 21 August 2014 by Admin (talk | contribs) (→File Burning)
Melzi V2.0 is a compact all-in-one control board which supports only one extruder. Its plug-and-play capability contributes to less time consuming for development and installation. Melzi V2.0 is a quiet mature product with good stability. Melzi 2.0 is based on Arduino Leonardo, so it is more accurate in temperature detection. MelziV2.0 has the following amelioration compared with V1.0: the MOSFET of heatbed and extruder have better capacity of heat dissipation; SD slot adopts outer lead bonding, improving the stability of reading and writing, protecting sd car from damage. When connected to PC, the LED will give prompts for users to know the connection.
Features: 1. Operating voltage: 12v
2. Main control IC: ATMEGA1284P from ATMEL
3. FT232RL USB interface
4.4 integrated A4988 stepper motor driver
5.MK1、MK2a、MK2b、MK3 controllable hotbed MK1、MK2a、MK2b、MK3
6. Mini SD card slot that integrates G code files.
7. The integration of 3 MOSFET driver amphenol connectors for hotbed, fan and extruder.
Size :210mm *50mm Weight:70g
Software Resources
Pc software:
Interface specifications
1 ADC interfaces for thermometry: one for extruder and another for hotbed.
2 PWM to control extruder, hotbed and fan.
3 end stops for x/y/z axis (mechanical).
Jumper Instruction
Power supply of logic part: connect 1 and 2 for external power supply; connect 2 and 3 for power supply from USB.
File Burning
Configuring serial interface: Tools > Serial Port > the corresponding COM Port of MElzi V2.0 is usually the last one. As shown below
Click the check“ File:Button 1” button to check if it is right and then click the “File:Button 2 ” button to upload firmware, as shown below.
Upon uploading, IDE will display the rate of progress; when done uploading appears, the uploading process succeeded.
Software Setting
Arduino IDE Installation
Windows will prompt that a new USB device, named FT232R USB UART was found when connecting PS to the PC with USB. Then, windows will open the dialog box “found new hardware wizard”, check “no, not this time”, then click “next” to continue.
If everything goes well, windows will install the corresponding driver.
Now, you can find the corresponding Printrboard device in device manager of windows.
Click configuration > printer setting
Set the communication port (the COM port for Melzi V2.0) and the Baud rate. Then click ok
Click “connect”> upload. Choose the GCODE file you want to print.
Get Started
Melzi V2.0 is the CPU of a 3D printer, manipulating the whole process of printing. Melzi V2.0 can’t be put in use directly without uploading firmware.
 #define BAUDRATE 250000
 #define MOTHERBOARD 63
This parameter is set for board type. 3D Printer has many types of main board, and the settings of IOs are different, therefore, the parameter has to correspond to the type of your board, or it can’t operate normally. The parameter of Melzi V2.0 should be 63(single- nozzle). For other board, you can refer to the annotation on the board.
 #define TEMP_SENSOR_0 3
 #define TEMP_SENSOR_BED 3
 #define EXTRUDE_MINTEMP 170
 #define INVERT_X_DIR false
 #define INVERT_Y_DIR true
 #define X_HOME_DIR -1
 #define Y_HOME_DIR -1
 #define Z_HOME_DIR -1
 #define X_MAX_POS 205
 #define X_MIN_POS 0
 #define Y_MAX_POS 205
 #define Y_MIN_POS 0
 #define Z_MAX_POS 200
 #define Z_MIN_POS 0
Extensible Applications
Upload firmware with Bluetooth through USB《-》rs232(TX/RX)
The COM should be set as (9600, N, 8, 1)
The command for Bluetooth module:
 AT OK
 AT+BAUD8 OK115200BAUD (set baud rate for Melzi)
 AT+NAMEHUXLEY OKsetname (optional set name, default: linvor)
 AT+PIN0000 OKsetPIN (optional set pin, default: 1234)
Connection:
FAQS
2. How to solve it if the driver installation failed?
Click here to reinstall the driver((http://www.geeetech.com/wiki/index.php/Sanguinololu)
