PEEK J-head short-distance
Revision as of 00:50, 23 June 2014 by Admin (talk | contribs) (→Product Introduction)
parts to a bare minimum. The J-Head Hot End can easily and well interface with the most popular RepRap extruders. The filament path is same with teh one of an already proven design, it can be used to print reliably with both ABS and PLA. If using PLA, it requires a small fan to provide air-flow through the cooling vents milled in the sides of the nozzle holder. Besides, the Hot End has another two advantages. Heat transmission is more efficiency as there is no thermal junction where a separate heater screws onto the nozzle. And a resistor is used as a heater. There is no need to wrap nichrome wire or to bake a heater core.
Advantages
  • Internally, the filament path is identical to that of an already proven design.
  • The design is simple as the number of custom machined parts is kept to a minimum.
  • If necessary, the PTFE liner can be replaced by using an off-the-shelf piece of PTFE tubing.
  • The PTFE is not stressed nor used to provide support. This reduces a point of failure that is part of other designs.
  • A resistor is used as a heater. There is no need to wrap nichrome wire or to bake a heater core.
  • Heat transmission is improved as there is no thermal junction where a separate heater screws onto the nozzle.
Printing resolution 0.1mm
Molding form FDM
Material PEEK
Nozzle temperature 180℃-240℃
Outline dimensions 18*65*15mm L/H/W
Weight 50g
Input voltage default to 12V
Cartridge heater 12V 30W
Click here to buy PEEK J-head short-distance
