Arduino YUN
Revision as of 10:21, 23 May 2014 by Admin (talk | contribs) (→Summary)
AVR Arduino microcontroller
Microcontroller ATmega32u4
Operating Voltage 5V
Input Voltage 5V
Digital I/O Pins 20
PWM Channels 7
Analog Input Channels 12
DC Current per I/O Pin 40 mA
DC Current for 3.3V Pin                50 mA
Flash Memory 32 KB (of which 4 KB used by bootloader)
SRAM 2.5 KB
EEPROM 1 KB
Clock Speed 16 MHz
Linux microprocessor
Processor Atheros AR9331
Architecture MIPS @400MHz
Operating Voltage                        3.3V
Ethernet IEEE 802.3 10/100Mbit/s
WiFi IEEE 802.11b/g/n
USB Type-A 2.0 Host/Device
Card Reader Micro-SD only
RAM 64 MB DDR2
Flash Memory 16 MB
PoE compatible 802.3af card support (see the note below)
