Arduino YUN
AVR Arduino microcontroller
- Microcontroller ATmega32u4
- Operating Voltage 5V
- Input Voltage 5V
- Digital I/O Pins 20
- PWM Channels 7
- Analog Input Channels 12
- DC Current per I/O Pin 40 mA
- DC Current for 3.3V Pin 50 mA
- Flash Memory 32 KB (of which 4 KB used by bootloader)
- SRAM 2.5 KB
- EEPROM 1 KB
- Clock Speed 16 MHz
Linux microprocessor
- Processor Atheros AR9331
- Architecture MIPS @400MHz
- Operating Voltage 3.3V
- Ethernet IEEE 802.3 10/100Mbit/s
- WiFi IEEE 802.11b/g/n
- USB Type-A 2.0 Host/Device
- Card Reader Micro-SD only
- RAM 64 MB DDR2
- Flash Memory 16 MB
PoE compatible 802.3af card support (see the note below)
