Arduino Voice Recognition Module
Revision as of 02:27, 29 April 2014 by Admin (talk | contribs) (→Example 1)
We've beening thinking about a module which helps to control other devices by voice and it will not cost too much. Finally we designed this module. Well, what can this module do? It can recognize as much as 15 voice instruction, which is suitable for most cases involving voice control.
Parameters
1、Voltage:4.5-5.5V
2、Current:<40mA
5、Size: 30mm x 47.5mm
Example 1
1. Recording
Please record the following voice instrctions in order :
1、WHITE
2、RED
3、GREEN
4、BLUE
5、OFF
2. Hardware connection
3. Code
int redPin = 11; // R petal on RGB LED module connected to digital pin 11 int greenPin = 9; // G petal on RGB LED module connected to digital pin 9 int bluePin = 10; // B petal on RGB LED module connected to digital pin 10 byte com = 0; //reply from voice recognition
   delay(2000);
   Serial.write(0xAA);
   Serial.write(0x37);
   delay(1000);
   Serial.write(0xAA);
   Serial.write(0x21);
void loop() // run over and over again {
   while(Serial.available())
       com = Serial.read();
       switch(com)
           case 0x11:
                    break;
           case 0x12:
                    break;
           case 0x13:
                    break;
           case 0x14:
                    break;
           case 0x15:
           break;
void color (unsigned char red, unsigned char green, unsigned char blue) // the color generating function {
