Breakout Board for microSD Transflash
- SPI mode
- Support voltage:3.0 to 3.6V
- Sits directly on a Arduino
1.Sometime you're not sure whether a card is working or not,you must test it.
Now,let's go.
// include the SD library:
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
while (!Serial) {
pinMode(10, OUTPUT); // change this to 53 on a mega
return;
} else {
// print the type of card
switch(card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
break;
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
break;
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
break;
default:
Serial.println("Unknown");
if (!volume.init(card)) {
return;
uint32_t volumesize;
Serial.println();
Serial.println(volumesize);
volumesize /= 1024;
volumesize /= 1024;
root.openRoot(volume);
void loop(void) {
Open Serial Monitor
OK,the card is working.
2.You can connect the microSD transflash to 3D printer.
Click here to buy Editing Breakout Board for microSD Transflash
