Breakout Board for microSD Transflash
Compatible with the SPI interface found on any SD card, this tiny form factor was created for cell phone storage and is perfect for your next MP3 project!
- SPI mode
- Support voltage:3.0 to 3.6V
- Sits directly on a Arduino
Sometime you're not sure whether a card is working or not,you must test it.
// include the SD library:
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
while (!Serial) {
pinMode(10, OUTPUT); // change this to 53 on a mega
return;
} else {
// print the type of card
switch(card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
break;
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
break;
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
break;
default:
Serial.println("Unknown");
if (!volume.init(card)) {
return;
uint32_t volumesize;
Serial.println();
Serial.println(volumesize);
volumesize /= 1024;
volumesize /= 1024;
root.openRoot(volume);
void loop(void) {
Open Serial Monitor
