Arduino GPRS Shield
- GPRS multi-slot class 10/8
- GPRS mobile station class B
- Compliant to GSM phase 2/2+
- RTC supported.
- Selectable serial port.
- Speaker and Headphone jacks
Application Ideas
Cautions
Hardware Diagram
Power select - select the power supply for GPRS shield(external power or 5v of arduino); Power jack - connected to external 4.8~5VDC power supply; Antenna interface - connected to external antenna Serial port select - select either software serial port or hareware serial port to be connected to GPRS Shield Hardware Serial - D0/D1 of Arduino/Seeeduino Software serial - D7/D8 of Arduino/Seeeduino only Status LED - tell whether the power of SIM900 is on Net light - tell the status about SIM900 linking to the net UART of SIM900 - UART pins breakout of SIM900 Microphone - to answer the phone call Speaker - to answer the phone call GPIO,PWM and ADC of SIM900 - GPIO,PWM and ADC pins breakout of SIM900 Power key - power up and down for SIM900
Pins usage on Arduino D0 - Unused if you select software serial port to communicate with GPRS Shield D1 - Unused if you select software serial port to communicate with GPRS Shield D2 - Unused D3 - Unused D4 - Unused D5 - Unused D6 - Unused D7 - Used if you select software serial port to communicate with GPRS Shield D8 - Used if you select software serial port to communicate with GPRS Shield D9 - Used for software control the power up or down of the SIM900 D10 - Unused D11 - Unused D12 - Unused D13 - Unused D14(A0) - Unused D15(A1) - Unused D16(A2) - Unused D17(A3) - Unused D18(A4) - Unused D19(A5) - Unused Note: A4 and A5 are connected to the I2C pins on the SIM900. The SIM900 however cannot be accessed via the I2C .
Getting Started
Indicator LEDs
Power Up the GPRS Shield
void powerUp()
pinMode(9, OUTPUT);
digitalWrite(9,LOW);
delay(1000);
digitalWrite(9,HIGH);
delay(2000);
delay(3000);
void powerDown()
pinMode(9, OUTPUT);
delay(1000);
delay(2000);
delay(3000);
UNDER-VOLTAGE WARNNING
OVER-VOLTAGE WARNNING
UNDER-VOLTAGE POWER DOWN
OVER-VOLTAGE POWER DOWN
+CMTE:1
+CMTE:-1
+CMTE:2
+CMTE:-2
Upload Sketch to Arduino
- Connect the Arduino Duemilanove (or Seeeduino) to your computer using a USB cable.
//at 19200 bps 8-N-1
#include <SoftwareSerial.h>
SoftwareSerial GPRS(7, 8);
int count=0; // counter for buffer array
GPRS.begin(19200); // the GPRS baud rate
Serial.begin(19200); // the Serial port of Arduino baud rate.
if (GPRS.available()) // if date is comming from softwareserial port ==> data is comming from gprs shield
while(GPRS.available()) // reading data into char array
buffer[count++]=GPRS.read(); // writing data into array
if(count == 64)break;
Serial.write(buffer,count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardwareserial port ==> data is comming from PC or notebook
GPRS.write(Serial.read()); // write it to the GPRS shield
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
{ buffer[i]=NULL;} // clear all index of array with command NULL
+CFUN: 1
+CPIN: READY
Call Ready
SoftwareSerial library Notes
A Simple Source Code Examples
IDE: Arduino 1.0 or later
to your account at cosm.com
#include <String.h>
mySerial.begin(19200); // the GPRS baud rate
delay(500);
switch(Serial.read())
case 't':
SendTextMessage();
break;
case 'd':
DialVoiceCall();
break;
case 'h':
SubmitHttpRequest();
break;
case 's':
Send2Pachube();
break;
if (mySerial.available())
///SendTextMessage()
void SendTextMessage()
mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(100);
delay(100);
delay(100);
delay(100);
mySerial.println();
///DialVoiceCall
void DialVoiceCall()
delay(100);
mySerial.println();
///SubmitHttpRequest()
void SubmitHttpRequest()
mySerial.println("AT+CSQ");
delay(100);
delay(100);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(4000);
ShowSerialData();
delay(2000);
ShowSerialData();
delay(2000);
ShowSerialData();
delay(1000);
ShowSerialData();
ShowSerialData();
delay(300);
ShowSerialData();
mySerial.println("");
delay(100);
///send2Pachube()///
void Send2Pachube()
delay(100);
ShowSerialData();
delay(1000);
ShowSerialData();
delay(300);
ShowSerialData();
delay(2000);
ShowSerialData();
delay(3000);
ShowSerialData();
delay(2000);
ShowSerialData();
delay(4000);
ShowSerialData();
String temperature = "30";//
String barometer = "60.56";//
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
delay(500);
ShowSerialData();
mySerial.println();
ShowSerialData();
delay(100);
ShowSerialData();
void ShowSerialData()
Schematics
GPRSshield_sch.pdf
Resources
SIM900_hd_v1.06.pdf
NewSoftLibrary
GPRS Shield can be ordered through the Getech store. Its product page is located here
