Accessories
Revision as of 03:38, 15 December 2011 by Admin (talk | contribs) (→3.5" Display with TouchPanel)
Accessories
Accessories for the FriendlyARM boards and modules.
  • Outer Dimension: 78 x 110 mm
  • Display-Panel: N35 / T35 / X35 / W35, Datasheet
4.3" Display with TouchPanel
  • Outer Dimension: 110 x 88 mm
  • Display-Panel: N43, Datasheet
7" Display with TouchPanel
Outer Dimension: 180 x 130 mm Display-Panel: A70, Datasheet
LCD2VGA Adapter
Resolution: 1024x768 70Hz (VGA)
USB WiFi Module
  • WLAN: IEEE 802.11b/g
  • Data Rate: Up to 54 Mbps
  • Chipset: VIA VT6656
SD WiFi Module
  • Chipset: Marvell 8686
CAM130 CMOS-Camera Module
  • Pixel: 1.3 megapixel
  • Resolution: 640 x 480 / 1280 x 1024
  • Color: 24 bit
  • Transmission rate: 30/15 fps
  • Chip: OV9650
Serial Adapter
TTL level to RS232 level converter
Power Supply
  • Output: 5V (regulated)
  • DC-Plug: 1.35mm inner x 3.5mm outer diameter
