ADXL345 Triple Axis Accelerometer Breakout
This is a breakout board for Analog Devices ADXL345 3-Axis Accelerometer.The ADXL345 is a small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16 g. Digital output data is formatted as 16-bit twos complement and is accessible through either a SPI (3- or 4-wire) or I2C digital interface. The ADXL345 is well suited for mobile device applications. It measures the static acceleration of gravity in tilt-sensing applications, as well as dynamic acceleration resulting from motion or shock. Its high resolution (3.9 mg/LSB) enables measurement of inclination changes less than 1.0°.
- Ultralow power: as low as 23 μA in measurement mode
- Fixed 10-bit resolution Full resolution, up to 13-bit resolution at ±16 g
- Single tap/double tap detection
- Activity/inactivity monitoring
- Free-fall detection
- Supply voltage range: 2.0 V to 3.6 V
- I/O voltage range: 1.7 V to VS
- SPI (3- and 4-wire) and I2C digital interfaces
Here is the guide illustrates how to connect an Arduino to the ADXL335 breakout board. The following is a table describing which pins on the Arduino should be connected to the pins on the accelerometer:
File:345 wiring.jpg File:ADX table.jpg
#include <Wire.h>
#define Register_ID 0
#define Register_2D 0x2D
#define Register_X0 0x32
#define Register_X1 0x33
#define Register_Y0 0x34
#define Register_Y1 0x35
#define Register_Z0 0x36
#define Register_Z1 0x37
int ADXAddress = 0xA7>>1;
int reading = 0;
int val = 0;
int X0,X1,X_out;
int Y0,Y1,Y_out;
int Z1,Z0,Z_out;
double Xg,Yg,Zg;
Wire.begin();
delay(100);
Wire.beginTransmission(ADXAddress);
Wire.send(Register_2D);
Wire.send(8);
Wire.endTransmission();
Wire.send(Register_X0);
Wire.send(Register_X1);
Wire.requestFrom(ADXAddress,2);
if(Wire.available()<=2);
X0 = Wire.receive();
X1 = Wire.receive();
X1 = X1<<8;
X_out = X0+X1;
Wire.send(Register_Y0);
Wire.send(Register_Y1);
Y0 = Wire.receive();
Y1 = Wire.receive();
Y1 = Y1<<8;
Y_out = Y0+Y1;
Wire.send(Register_Z0);
Wire.send(Register_Z1);
Z0 = Wire.receive();
Z1 = Wire.receive();
Z1 = Z1<<8;
Z_out = Z0+Z1;
Xg = X_out/256.00;
Yg = Y_out/256.00;
Zg = Z_out/256.00;
Serial.print(" X=");
Serial.print(Xg);
Serial.print(" Y=");
Serial.print(Yg);
Serial.print(" Z=");
Serial.println(Zg);
delay(300);
Click here to buy ADXL345 3-Axis Accelerometer Breakout
