4-Channel wireless RF Relay module
Introductin
4 groups of channels for high voltage connection:
- SET A,B,C- Normally open
Jumper selection:
- Unlocked mode:Jumper 1 and Jumper 2 are diselected. If the button on the remote control is pressed,the corresponding relay on the receiver board is closed until this button is released.
- Locked mode:Jumper 2 is selected. If the button on the remote control is pressed, the corresponding relay on the receiver board is closed until another button is pressed.
- Delay mode:Jumper 1 is selected.If the button on the remote control is pressed, the corresponding relay on the receiver board is closed for 2 second.
Click here to buy: http://www.geeetech.com/315mhz-rf-4-channels-wireless-relay-remote-control-module-p-531.html
