4-Channel wireless RF Relay module
Revision as of 02:41, 18 May 2012 by Admin (talk | contribs) (Usage)
Introductin
4 groups of channels for high voltage connection: SET A,B,C- Normally open
Jumper selection:
  • Unlocked mode:Jumper 1 and Jumper 2 are diselected. If the button on the remote control is pressed,the corresponding relay on the receiver board is closed until this button is released.
  • Locked mode:Jumper 2 is selected. If the button on the remote control is pressed, the corresponding relay on the receiver board is closed until another button is pressed.
  • Delay mode:Jumper 1 is selected.If the button on the remote control is pressed, the corresponding relay on the receiver board is closed for 2 second.
Click here to buy [4-channel RF Wireless Relay Remote Control Module]
