4-Channel wireless RF Relay module
Revision as of 02:40, 18 May 2012 by Admin (talk | contribs) (→Usage)
Introductin
4 groups of channels for high voltage connection: SET A,B,C- Normally open
Jumper selection:
  1. Unlocked mode:Jumper 1 and Jumper 2 are diselected. If the button on the remote control is pressed,the corresponding relay on the receiver board is closed until this button is released.
  1. 2 Locked mode:Jumper 2 is selected. If the button on the remote control is pressed, the corresponding relay on the receiver board is closed until another button is pressed.
3#Delay mode:Jumper 1 is selected.If the button on the remote control is pressed, the corresponding relay on the receiver board is closed for 2 second.
Click here to buy [4-channel RF Wireless Relay Remote Control Module]
