Accessories
Accessories
Accessories for the FriendlyARM boards and modules.
3.5" Display with TouchPanel
- Outer Dimension: 78 x 110 mm
- Display-Panel: N35 / T35 / X35 / W35, Datasheet
4.3" Display with TouchPanel
- Outer Dimension: 110 x 88 mm
- Display-Panel: N43, Datasheet
7" Display with TouchPanel
Outer Dimension: 180 x 130 mm Display-Panel: A70, Datasheet
LCD2VGA Adapter
Resolution: 1024x768 70Hz (VGA)
USB WiFi Module
- WLAN: IEEE 802.11b/g
- Data Rate: Up to 54 Mbps
- Chipset: VIA VT6656
SD WiFi Module
- Chipset: Marvell 8686
CAM130 CMOS-Camera Module
- Pixel: 1.3 megapixel
- Resolution: 640 x 480 / 1280 x 1024
- Color: 24 bit
- Transmission rate: 30/15 fps
- Chip: OV9650
Serial Adapter
TTL level to RS232 level converter
