Accessories
Revision as of 03:06, 15 December 2011 by Admin (talk | contribs) (→USB WiFi Module)
Accessories
Accessories for the FriendlyARM boards and modules.
3.5" Display with TouchPanel
  • Outer Dimension: 78 x 110 mm
  • Display-Panel: N35 / T35 / X35 / W35, Datasheet
4.3" Display with TouchPanel
  • Outer Dimension: 110 x 88 mm
  • Display-Panel: N43, Datasheet
7" Display with TouchPanel
Outer Dimension: 180 x 130 mm Display-Panel: A70, Datasheet
LCD2VGA Adapter
Resolution: 1024x768 70Hz (VGA)
USB WiFi Module
WLAN: IEEE 802.11b/g Data Rate: Up to 54 Mbps Chipset: VIA VT6656
SD WiFi Module
CAM130 CMOS-Camera Module
Serial Adapter
Power Supply
