Geeetech Thunder 3D printer
Revision as of 08:19, 1 July 2023 by Admin (talk | contribs)
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
How to clean the hotend
How to replace a nozzle
2. Remove the heat block kit.
How to replace a hotend
1. Disassemble the hotend kit
2. Install the new hotend kit
Nothing is printing
Mintemp error
Automatic leveling failed
(a)3D Touch is abnormal
(b)Homing failed
(c)The first layer is messy
Spring steel sheet problem
Filament sensor
Nozzle discharge abnormality
First layer abnormal
Layer shift
=='Filament'==
Part Cooling Fan:
M106 P0 S128 ; ON MainFan 50%
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
