Geeetech Thunder 3D printer
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Product Features
•Technology: FDM
•Dual Z-axis
Parameters
Notice
Cura Configuration File
User Mode Introduction
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Usage Suggestions
How to clean the hotend
How to replace a nozzle
2. Remove the heat block kit.
- d.Release the screw terminals for heater cartridge and remove the cables. Unplug the cables of hotend and the hotend fan.
- d.Place back all the pieces to reassemble the print head. Make sure the cables are fully inserted and tightened!
How to replace a hotend
1. Disassemble the hotend kit
2. Install the new hotend kit
Nothing is printing
Mintemp error
Automatic leveling failed
(a)3D Touch is abnormal
(b)Homing failed
(c)The first layer is messy
Spring steel sheet problem
Filament sensor
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
Part Cooling Fan:
M106 P0 S128 ; ON MainFan 50%
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
How to Acquire Support
Steps:
