Geeetech Thunder 3D printer
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
Cura Configuration File
User Mode Introduction
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Usage Suggestions
How to clean the hotend
1.Heat up the nozzle to 200 ℃, then remove the PTFE tube.
2.Use another piece of PLA filament to push through from the top to try to force the stuck filament in the nozzle out.
3.If you find that the hotend is still blocked, then you maybe able to use a small metal rod to push it in and out several times, making the clogging out. Do not use excessive force.
How to replace a nozzle
1.Turn the printer off and unplug the power cable.
2.Remove the hotend housing, and one of the blower fans and its bracket.
3.Disconnect the cables of hotend cooling fan and the two blower fans.
4.Unscrew the extension board and put it aside.
5.Turn the printer on and preheat hotend.
6.Wear gloves to prevent burns. Place the socket wrench vertically to unscrew the nozzle. Otherwise it is easy to misalign the screw and thread, causing the breakage of the nozzle in the heat block.
7.Place the socket wrench vertically to install the new nozzle. Do not use excessive force.
8.Place back all the pieces to reassemble the print head. It is done!
- Disassemble the printhead partially.
- Remove the heat block kit
- Numbered list item
- d.Release the screw terminals for heater cartridge and remove the cables.Unplug the cables of hotend and the hotend fan.
- Install the new heat block kit
- d.Place back all the pieces to reassemble the print head.Make sure the cables are fully inserted and tightened!
Warning Tie the wires properly, otherwise it will scratch the model during printing, leading the wires disconnected.
It's done. Heat up the printer and try it out.
How to replace a hotend
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
Part Cooling Fan:
M106 P0 S128 ; ON MainFan 50%
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
How to Acquire Support
Steps:
