Mini210
Revision as of 03:16, 13 December 2011 by Admin (talk | contribs)
Mini210 | S5PV210 ARM Cortex-A8 Board
FriendlyARM Mini 210 SBC (Single-Board Computer) with 1 GHz Samsung S5PV210 ARM Cortex-A8 processor. The board measures 130 x 115 mm, ideal for learning about ARM Cortex-A8 systems.
Mini210 Schematics
  • Dimension: 130 x 115 mm
  • CPU: 1 GHz Samsung S5PV210 with PowerVR SGX540 graphics engine
  • RAM: 512 MB DDR2 RAM, 32 bit Bus
  • Flash: 1GB NAND Flash
  • EEPROM: 256 Byte (I2C)
  • Ext. Memory: 2x microSD-Card socket
  • Serial Ports: 1x DB9 connector (RS232), total: 4x serial port connectors
  • IR: Infrared Receiver
  • USB: 1x USB-A Host 2.0, 1x miniUSB Slave/OTG 2.0
  • Audio Output: 3.5 mm stereo jack, connector for a speaker (Class D Amp)
  • Audio Input: Condenser microphone
  • Ethernet: RJ-45 10/100M (DM9000)
  • WiFi/WLAN: onboard SD-WiFi with ceramic antenna
  • RTC: Real Time Clock with battery
  • Beeper: PWM buzzer
  • Camera: 2x 20 pin (2.0 mm) Camera interface
  • TV Output
  • Monitor: miniHDMI (type C)
  • LCD Interface: 50 pin (2.0 mm) and 41 pin (1.0 mm) connector for FriendlyARM Displays
  • User Inputs: 8x push buttons and 1x A/D pot
  • User Outputs: 4x LEDs
  • Expansion: 40 pin GPIO (ADC, I2S, I2C, SPI, PWM, IO...), 20 pin SDIO (SD, SPI, I2C), 20 pin Buttons (2.0 mm)
  • Debug: 10 pin JTAG (2.0 mm)
  • Power: regulated 5V (DC-Plug)
  • OS Support
    • Linux 2.6
    • Android
Board
Click here:http://www.geeetech.com/armavr-series-arm11-c-9_52.html
