Iduino Yun Cloud
OverView
interface explanation
- Open source Linux (OpenWrt) onboard
- Compatible with Arduino IDE 1.5.4 or later, user can program, debug or upload sketches to the Arduino board via the Arduino IDE.
- Built-in web server
- Supports internet connection via LAN port, WiFi or 3G dongle.
- Supports USB flash to provide storage for Arduino projects.
- Failsafe design provides robust system.
AVR Arduino microcontroller
- Microcontroller ATmega32U4
- Operating Voltage 5V
- Input Voltage 5
- Digital I/O Pins 20
- PWM Channels 7
- Analog Input Pins 12
- DC Current per I/O Pin 40 mA
- DC Current for 3.3V Pin 50 mA
- Flash Memory 32 KB (of which 4 KB used by bootloader)
- SRAM 2.5 KB
- EEPROM 1 KB
- Clock Speed 16 MHz
Linux Microprocessor
- Processor Atheros AR9331
- Architecture MIPS @400MHz
- Operating Voltage 3.3V
- Ethernet IEEE 802.3 10/100Mbit/s
- WiFi IEEE 802.11b/g/n
- USB Type-A 2.0 Host
- Card Reader Micro-SD only
- RAM 64 MB DDR2
- Flash Memory 16 MB
WiFi Specification
- WiFi: Support 150M 2.4Ghz WiFi, 802.11 b/g/n
- Frequency range: 2.4~2.4835GHz
- Modulation: BPSK, QPSK, CCK and OFDM (BPSK/QPSK/16-QAM/ 64-QAM)
- Sensitivity @PER: 135M : -65dBm@10%PER; 65M : -65dBm@10%PER; 54M : -68dBm@10%PER;
11M : -84dBm@8% PER; 6M : -88dBm@10% PER; 1M : -90dBm@8% PER
- Typical Distance: Indoor: 60m (max); Outdoor 150m (max) (with 2 dBi antenna)
- RF Power: 11n: 13dBm; 11g: 13-15dBm, 11b: 16-18dBm,
- Connector: I-PEX connector.
USB Ports
The Iduino Yun Cloud has two USB connectors for different purpose:
- USB Type A Female: Connect to the Linux part. it is a USB host port. User can use it to connect to USB flash, 3G dongle etc.
- USB micro A Female: Connect to Atmega32u4, use can use it to upload sketch to Atmega32u4 or get debug info from 32u4.
Buttons:
- WLAN_RESET: Reset Linux part.see here
- 32u4_RSET: Reboot Atmega32u4
- YUN_RST: Reboot Linux part
Quick Start of Iduino Yun
Connect to Iduino Yun
Power on Iduino Yun, after the system runs, it will generate a WiFi network with SSID : I duino-A84041XXXXXX.
Upload Bridge example
"YUNs_IP/arduino/digital/13" -> digitalRead(13) "YUNs_IP/arduino/digital/13/1" -> digitalWrite(13, HIGH) "YUNs_IP/arduino/analog/2/123" -> analogWrite(2, 123) "YUNs_IP/arduino/analog/2" -> analogRead(2) "YUNs_IP/arduino/mode/13/input" -> pinMode(13, INPUT) "YUNs_IP/arduino/mode/13/output" -> pinMode(13, OUTPUT)
Test the sketch
User Manual
Getting IP address
Factory IP of Wifi port
FallBack IP
If the user’s laptop IP is
Detect IP from Arduino IDE
Access Method
Webpage access
SSH Access
SSH Access:
- Port: 22
- User Name: root
- Password: iduino (default)
Webpage Setting
General setting
Upgrade
1 How to set up /www/sd and mnt/sd?
2 What if Arduino IDE doesn’t detect Iduino Yun Shield?
- If the Iduino Yun boots in advance than Arduino IDE, this situation may happen. So try to reboot the Iduino Yun and check again.
3 Where can you find the source code of the Iduino Yun?
4 How to upload, download or edit the files in Iduino Yun?
- User name: root
- Protocol: SCP
5 How to reset Iduino Yun?
- If pressing the WLAN_RESET and release after 5 seconds, it will reset the Wifi setting and other settings will be kept.
- If pressing the WLAN_RESET and release after 30 seconds, it will reset all the settings to factory default.
6 How to recover the Iduino Yun in case firmware crash?
5.Set TPFP service:
- (2)Host: 192.168.255.2
- Port:6666
- Port:6666
- Module IP: 192.168.255.1
- Port: 6666
- Local Port: 6666
reset<CR>
Relevant file:
- Warning: User should use correct address in the erase and cp.b. Wrong address may destroy the boot-loader of Iduino Yun and the device won’t boot anymore, or destroy the radio data leading to a poor Wifi performance or incorrect MAC address.
