Iduino Yun Cloud
Interface layout
Interface specifications
How to set up Iduino Yun cloud
Use Yun cloud with Arduino board
Connect to Arduino Board
Connect to Leonardo
Connect to Arduino Uno
Connect to Arduino Mega2560
Detect Iduino_Yun_Shield
Upload Sketch
