Delta Rostock mini G2
Main features:
Specifications:
The Layer Thickness: 0.1mm
Layer Resolution: 0.1mm
Print Speed: 60 to 120 mm/sec
Print Plate Size: 210 x 3mm
XYZ Bearings: carbon steel
Output:DC12V/0-15A
No. of Extruders: 1
Electronics: GT2560
Machine weight: 7.5kg
Shipping box dimensions:
Shipping box weight:
building instruction
install drivers and software
Install the drivers
here.
Macbook (OS X) Manual Install
Click "Continue" in Read me.
Click "Continue" in License.
How to set up
Printer setting
Home X: 0
Home Y: 0
Home Z: Max
Printer Radius: 100mm
Printable height: 210mm
Start G29 Command
Printer preparing
1)send command: G0 X0 Y50 Z2, record the distance;
