Delta Rostock mini G2
Main features:
Specifications:
The Layer Thickness: 0.1mm
Layer Resolution: 0.1mm
Print Speed: 60 to 120 mm/sec
Print Plate Size: 210 x 3mm
XYZ Bearings: carbon steel
Output:DC12V/0-15A
No. of Extruders: 1
Electronics: GT2560
Machine weight: 7.5kg
Shipping box dimensions:
Shipping box weight:
building instruction
install drivers and software
Install the drivers
here.
Macbook (OS X) Manual Install
Click "Continue" in Read me.
Click "Continue" in License.
