Acrylic Prusa I3 build instruction(8mm)
Notice:
Unfold and check the package
Tips:
Assemble the rods of a Y axis
Assemble the Y idler
Mount the Y motor
Insert the motor block into the slot; you may need to use a little strength to do this. But be careful in case the Acrylic broke down. Then screw the motor on the block plate with M3 x 12 screws.
Build the printing platform
Step2. Mount the 4 Acrylic fenders on the platform with M3 x 20 screws and M3 nuts on the same side with the belt-mount.
Step4. Mount the belt.
Drill a hole on one end of the belt(the hole can be as the diameter of the M3 screw, leave enough margin )
Fix it on the belt -mount with a M3 x 10 screw and washer.
Thread the belt through the pulley on the Y motor and the Y idler.
Drill a hole on the other end of the belt and fix it on the belt -mount with a M3 x 10 screw and washer.
Attach the heated bed
You can also attach the heated bed later.
Solder the heating wire on the edge of the bed.
Take out the 2-pin DuPont wire and take off one the adapter.
Solder the DuPont wire and the thermistor together.
Attach the DuPont wire and the thermistor on the bed with Kapton tape.
Assemble Y - Z axis
The main frame is held upright after the acrylic fender washers on the Y axis threaded rods. The front of the plate should be sticking out a lot further than the back. Screw up the frame to the threaded rod of Y-axis.
Mount the fan
Screw up the X-Z frame and the side panel then connect the rear part of the Y axis and the side panel together. You may need to adjust the distance of the X-Z frame to the rear plate.
Screw up the acrylic plates with M3 x 16 screws and M3 square nuts.
Assemble the 2 Z motors
Step2. Screw up the motors with M3 x 12 screws.
Assemble the X-Axis Idler
Put the screw through the printed Y idler piece, with the 624ZZ bearings in between. Lock the other end of a M3 nut.
Mount the assembled idler into the X-axis end. Lock it up with a wing nut. Here, you can insert the linear bearing into the end.
Insert a linear bearing into the other end of X-axis.
Thread the two rods into the two X-axis ends and then mount the brass nut under both ends.
Thread the zip-tie through the extruder bracket
Step1. Mount the X-axis belt bracket on the smooth rods. As you can see from the picture, the two linear bearings should be placed into the two slot of the bracket. Tie them up with zip ties.
Mount the extruder support
1.Put the 2 M4 nut into the hole, as shown in the picture.
2. Screw up the belt bracket and the extruder support with two M4 x 16screws.
Mount the extruder
This is the fully assembled MK8 extruder in the package.
Mount the aluminum plate under the extruder.
Then mount the assembled extruder on the extruder support. Use 2 M4 x 12 screws to fix. (the blue extruder support)
Mount the X-axis motor
Amount the X-axis belt
Thread the belt through the motor end. The belt is attached on the pulley.
Another end of the belt should be threaded through the belt holder on the right end of the X-axis.
Assemble the X-Z axis
Mount the end stops
Step 1.End stop of X-axis
Step2. End stop of Y-axis
Step3. End stop of Z-axis
Mount the LCD panel frame
Mount the filament spool
Mount the PSU
Mount the PSU on the right side panel with 3 M3 x 10 screws.
Example 1: Sanguinololu
Example 2: Ramps 1.4
Wiring
3.Connect the heatbed.
4.Connect the extruder
5.Connect the end stops.
6.Connect the power supply.
