Assemble Manual of Geeetech Acrylic Prusa I3 (5mm)
Prologue Note: This manual only applies to the 5-mm acrylic Prusa I3. We have another one that is 8-mm.
As picture is much more helpful than words in assembly manual, so I use plenty of pictures and less word.
1.1Assemble the rods of a Y axis
Required parts Part ID
M10 450mm threaded rod
No.5
Acrylic Fender
NO.A 12
M8 spring washer
NO.17
M10 washer
NO.7
M10 nut
NO.12
Step1. Assemble the threaded rod
Thread the nuts and washers on the two M10 threaded rods separately. The order should be:
M10 washer > M8 spring washer M10 screw > M10 screw > M10 washer > >A 12> M10 washer > M8 spring washer > M10 screw > M10 screw > M8 spring washer > M10 washer
Step2. Assemble the Y axis smooth rod
Slide 2 bearings on each smooth rod. Before you slide the bearings please make sure they are clean. (Ignore the black one in between)
M8 410mm smooth rod
NO.3
LM8UU Linear Bearings
NO.32
Acrylic plate
NO.A7,A8,A9,A10
M3 nut
NO.10
Acrylic Fender
NO.A11
Assemble the Y idler
624ZZ Ball Bearing
NO.31
Printed Y idler
NO.P8
M4 X25 screw
NO.28
M4 nut
NO.11
Y bearing limit block
A18
Retaining ring
P9
Step1. put the M4 X 25 screw into the end of the Y idler, from outside to inside, and screw it up with a M4 nut.
Step2. Put the screw through the printed Y idler piece, with the 624ZZ bearings in between. Lock the other end of a M3 nut.
Step2. Mount the assembled idler onto the front support plates.
Mount the Y motor
Y-axis motor block
NO.A13,A14
Stepper motor
60
pulley
35
M3 screw
20,24
M3 nut
10
build the printing platform
Acrylic plate
NO.A17
Acrylic plate(No.A17)
NO.A17
Printed belt mount
NO.P4,P5
Belt
34
Zip tie
45
M3 screw
24
M3 nut
13
Step1. Mount the belt mount on the bottom side of the plate.
Step2. Get the build platform plate zip-tied to the 4 linear bearings.
Step3. Attach he heated bed.
Heat bed
56
Heating wire(No.A17)
42
Thermistor
Attached on the bed
Thermometry wire
41
Wing nut
15
Spring
30
M3 screw
24
The circled part need soldering.
Assemble Y - Z axis
The main frame is held upright after the acrylic fender washers on the Y axis threaded rods. The front of the plate should be sticking out a lot further than the back.
Acrylic left panel
NO.A2
Acrylic right panel
NO.A3
Acrylic rear block
NO.15
Zip tie
45
M3 screw
22
M3 nut
10
Mount the rear part of the Y axis and the side panel together.
Acrylic left panel
NO.A15
M3 screw
22,23
M3 nut
10
Step1. Assemble the Z-axis bottom mounts
Acrylic left panel
NO.A4
Acrylic right panel
NO.A5
Stepper motor
60
M3 screw
22,20
M3 nut
10
Assemble the 2 Z motors
Mount the fan on the left side
Fan
55
M3 screw
24
M3 nut
10
5Assemble the X axis (the horizontal axis)
File:Prusal I3 manual pic41.jpg
Step1. Assemble the X-Axis Idler
624ZZ Ball bearing
NO.31
Printed Y idler
NO.P8
M4 X25 screw
NO.28
M4 nut
NO.11
Retaining ring
P9
X-axis optical axis bracket
P2
Step2. Mount the idler into the following part
Step3. Assemble the 2 smooth rods.(380 mm)
Slide 2 bearings on the each rod as shown in the picture.
Slide the X-axis motor-end and the idler-end onto both ends of the smooth rods. The X-axis motor-end is on the left and the idler-end on the right. This is going to take some force, or you can use file to make the holes lager.
Mount the brass nut on the following part.
Insert the rest bearings into the bracket of both end of the smooth rod.
Thread the threaded rod through the following part. It would be easier to do it now.
Mount the aluminum plate under the extruder.
Fix the two pulleys on both if the threaded rod. And plug it on the motor shaft.
Assemble the X-Z axis.
Z-axis top mount
A6
Step1. thread the X-axis through the Z axis.
Step2 assemble the top mount of the Z-axis.
step1. Thread the zip-tie through the extruder bracket.
Step2. Mount the extruder bracket on the smooth rod and insert the two bearings into the bracket. Tie up the Y belt then.
Step3. Amount the extruder support.
Step4. Mount the extruder
This is the fully assembled MK8 extruder.
MK8 assemble board
65
Fix the assembled extruder on the blue part. Pay attention to the direction of the motor and the fan.
Pay attention to the exit of the red wire, it will affect the final wiring steps.
Mount the X-axis motor
Assemble the belt.
Pay attention to the tooth mesh of the belt and the part in red circle.
Mount the end stops
End stop of X-axis
X-axis bracket of end stop
P10
End stop
26
End stop of Y-axis
End stop
37
Z-axis bracket of end stop
P5
Note the direction of the switch.
End stop of Z-axis
End stop
38
P5
Mount the LCD panel frame
Mount the filament spool
So far, the framework of the 3D printer is almost finished.
mount the control board on the left side panel
Ramps 1.4 + Mega 2560 + A4988
Stack the Ramps 1.4on the Mega 2560 and plug the 5 A4988 on the Ramps 1.4.
Sanguinololu
Plug the 5 A4988 on Sanguinololu
Mount the PSU on the right side panel
Pay attention to the switch on the right side of the PSU, there are two options of voltage: 110 V and 220V, choose according the standard in your country.
Wiring
PSU wiring
Do make sure you connect the wires correctly, otherwise it may lead to damage to the control board and the PSU.
control board wiring
1)The referring wiring schematic diagram of Ramps 1.4
2) The referring wiring schematic diagram of Sanguinololu
Next is the testing and debugging.
