Me Creator
Revision as of 07:57, 23 January 2015 by Admin (talk | contribs) (Introduction)
Me Creator
  • High Cost-Effective
  • Resolution up to .1mm
Technical Specifications
Physical Dimensions
Printing Specifications
Layer Resolution:0.1mm
Filament Type:ABS, PLA
Filament Diameter:1.75mm
Temperature
Max Heated Bed Temp:0-110 ℃
Max Extruder Temp:0-250 ℃
Electrical
Power Requirement:120W
Connectivity:USB
Mechanical
Chassis:Steel Frame
Build Platform:Aluminum
Operation
Placement
Connectivity
Modifications
Warnings
Install the drivers
Windows 8
Windows Manual Install
How To Connect
Leveling The Print Bed
Belt Tensioning
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
2. To test the belts, you need to be able to move the belts. This requires the motors to be turned off. Go to the Manual Control tab in Repetier Host and click the "Stop Motor" button. You should now be able to move the extruder around without much resistance.
Unblocking Procedures
Types of Blocks
  • The Stubborn Filament
  • Filament broke mid print
Tweezers
Dental Pick
Filament
Long Skinny Metal Object
The Cold Block
  • Identification
  • Solution
The Hot Block
  • Identification
  • Solution
    • Solution 1: Break the block
Alternative: Acetone bath
Cleaning the Drive Gear
detailes 0f me creator
where to get
