Iduino Yun Shield
- Low power consumption
Overview and Hard ware Resources
front side -
back side
1. Processor: 400MHz, 24 MIPS
2. Flash: 16MB
3. RAM: 64MB
4. Power input: 4.75V~23V via Arduino Vin pin
5. 1×10M/100M RJ45
6. Connector 150M Wifi 802.11 b/g/n
7. External antenna via I-Pex
8. 1×USB port for USB storage or 3G connection
9. 1×Reset button
10. Compatible with 3.3V or 5V I/O Arduino
Size: 70mm * 53mm*24mm
Weight: 33.2g
Software Resource
Source
Interface layout
Interface layout -
wireframe
Interface specifications
Getting IP address
Factory IP of Wifi port
FallBack IP
Allocation pattern
Webpage access
SSH Access
SSH Access:
- Port: 22
- User Name: root
- Password: iduino (default)
Webpage Setting
General setting
Settings of Iduino
Arduino board Type: Define the setting of bootloader/mcu type/fuse during Sketch uploading Operation Mode: Make sure the mode is Arduino Bridge mode so that the Bridge class can work
Upgrade
Use with Arduino Board
1.Whether the Arduino board is powered by DC jack;
2.If the board type setting is correct in the Iduino_Yun_Shield;
3.If the board type setting is correct in the Arduino IDE;
4.Whether the Arduino SPI and UART is not influenced by other hardware
5.Make sure the UART mode is in Arduino Bridge.
Connect to Arduino Board
Connect to Leonardo
Connect to Arduino Uno
Connect to Arduino Mega2560
Detect Iduino_Yun_Shield
Upload Sketch
Example
Say hello to Linux
Code:
#include <Console.h>//use Console class for Arduino IDE debug over Wifi, similarto Serial class, String name; voidsetup() { // Initialize Console and wait for port to open: Bridge.begin(); Console.begin(); // Wait for Console port to connect while (!Console); Console.println("Hi, what's your name?");//Data flow: Arduino --> Yun Shield --> Arduino IDE } void loop() { if (Console.available() > 0) { char c = Console.read(); //read the next char received, data flow: IDE --> Yun Shield--> Arduino // look for the newline character, this is the last character in the string if (c == '\n') { //print text with the name received Console.print("Hi "); Console.print(name); Console.println("! Nice to meet you!"); Console.println(); // Ask again for name and clear the old name Console.println("Hi, what's your name?"); name = ""; // clear the name string } Else { // if the buffer is empty Cosole.read() returns -1 name += c; // append the read char from Console to the name string } } }
Test Interface:
In Hardware Aspect
In Software Aspect
1.Whether the Arduino version is 1.5.4 or later;
2.Whether you PC is in the same network with the Iduino_Yun_Shield;
3.If the Iduino_Yun_Shield boots in advance than Arduino IDE, this situation may happen. So try to reboot the Iduino_Yun_Shield and check again.
- User name: root
- Protocol: SCP
How to reset Iduino_Yun_Shield?
1.If pressing the toggle button and release after 5 seconds, it will reset the Wifi setting and other settings will be kept.
2.If pressing the toggle button and release after 30 seconds, it will reset all the settings to factory default.
Set up TFTP service
Download Hercules utility
- Protocol: UDP
- Module IP: 192.168.255.1
- Port: 6666
- Local Port: 6666
Connect the PC to Iduino_Yun_Shield
Power up Iduino_Yun_Shield to Failsafe mode
Upgrade Kernel
tftpboot 0x81000000 ms14-arduino-yun-kernel-xxx.bin
erase 0x9fea0000 +0x140000
Upgrade rootfs
tftpboot 0x81000000 ms14-arduino-yun--rootfs-squashfs-xxx.bin
erase 0x9f050000 +0xe50000
Reset to the new firmware
Reset
