Me Creator
Revision as of 06:47, 22 January 2015 by Admin (talk | contribs) (How To Connect)
Me Creator
  • High Cost-Effective
  • Resolution up to .1mm
Technical Specifications
Physical Dimensions
Printing Specifications
Layer Resolution:0.1mm
Filament Type:ABS, PLA
Filament Diameter:1.75mm
Temperature
Max Heated Bed Temp:0-110 ℃
Max Extruder Temp:0-250 ℃
Electrical
Power Requirement:120W
Connectivity:USB
Mechanical
Chassis:Steel Frame
Build Platform:Aluminum
Operation
Placement
Connectivity
Modifications
Warnings
Install the drivers
Windows 8
Windows Manual Install
How To Connect
Leveling The Print Bed
Belt Tensioning
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
Unblocking Procedures
Types of Blocks
  • The Stubborn Filament
  • Filament broke mid print
Tweezers
Dental Pick
Filament
Long Skinny Metal Object
The Cold Block
  • Identification
  • Solution
The Hot Block
  • Identification
  • Solution
    • Solution 1: Break the block
Alternative: Acetone bath
Cleaning the Drive Gear
detailes 0f me creator
where to get
