Me Creator
  • High Cost-Effective
  • Resolution up to .1mm
Operation
Placement
Connectivity
Make sure the heating plate and extruder are not heated when starting software. Power
We recommend plugging your Me Creator printer into a surge protector with a circuit breaker. Never attempt to open or fix your power supply. If you believe your power supply is not working properly, contact us asap.
Modifications
Warnings
Install the drivers
Windows
Windows 8
Windows Manual Install
Note: In some cases the drivers will not install on their own. The Solidoodle drivers for Windows can be found in the following link: Media:Serial install.zip
