Me Creator
  • High Cost-Effective
  • Resolution up to .1mm
Operation
Placement
Connectivity
Make sure the heating plate and extruder are not heated when starting software. Power
We recommend plugging your Me Creator printer into a surge protector with a circuit breaker. Never attempt to open or fix your power supply. If you believe your power supply is not working properly, contact us asap.
Modifications
Warnings
Install the drivers
Windows
Windows 8
When you attempt to install the unsigned 3rd party driver on Windows 8, you will most likely not be able to install because the file is not digitally signed. To get around this restriction, you must temporarily remove this restriction by following the instructions here.
