MK8 Extruder
Revision as of 03:12, 26 August 2014 by Admin (talk | contribs) (Created page with "==Introduction== File:QQ图片20140826105924.jpg The new version of MK7 extruder which gives 35% more power. The MK8 extruder has outstanding quality and the best perfor...")
The new version of MK7 extruder which gives 35% more power. The MK8 extruder has outstanding quality and the best performance for DIY and professional systems.
  • The extrusion nozzle: Standard 0.4mm
  • The material of Print: PLA 1.75MM, ABS 1.75MM
  • The flow rate of Nozzle: about 24cc / h
  • Sports shaft speed:40mm/s
  • The voltage of heating nozzle: 12V
  • Thermocouple: 100K
  • The operating voltage of cooling fan: 12V
  • Heating rods: 6mm, 12V, 40W
  • Net weight: 450g
  • Normal rking temperature: 190°-230°
NOTE: Make sure the maximum temperature is less than 280°
Feature
  • Heating nozzle voltage: 12 v
MK8 Drive Gear
This is a evolution of the MK7 Drive Gear. The smaller diameter gives 35% more power.
If you need a replacement gear, or you're designing your own custom project, this is the part! Very sharp teeth to dig into the plastic filament for the best grip ever. Direct drive of the filament will give better prints.
Our MK8 Drive Gear was Best In Test in the benchmark test from Airtripper.
You can find the benchmark test here: 3D Printer Extruder Filament Drive Gear Review & Benchmark
Made by precise machining of stainless steel. The drive gear includes a M3 set screw and is suitable for typical NEMA17 motor shaft (5mm).
Dimension: 11mm (height) x 9mm (diameter) Effective diameter: 7mm Bore dimension: ø5mm
MK8 Printhead Extruder Nozzle
  • Material: Brass
  • Size: 5x13mm
  • Output Diameter: 0.4mm
  • 3D Printing Application:
    • Can replace extruder nozzles included in certain printers.
