Tiny210
- 1GHz Samsung S5PV210 with PowerVR SGX540 graphics engine
- 512MB DDR2 RAM and 1GB NAND Flash
- LCD/Touch Screen, HDMI,TV out, Audio support
- TF card, USB Host/OTG support
- Ethernet, WiFi, serial port, GPIO
- Contain CPU board
- Linux 2.6.35 & Android 2.3 support
CPU board Hardware info
Multi-IO:
- 2 x 60 Pin 2.0mm space DIP connector
- 1 x 30 Pin 2.0mm space DIP connector
- 1 x 51 Pin 1.0mm space SMD connector
on Board: HDMI interface 4 x User Leds(Green) 1 x Power Led(Red)
Supply Voltage from 2V to 6V Mechanical: Dimension: 64x 50x 11mm Software: Android 4.0, Android 2.3, Linux 2.6.35, Qtopia-2.2.0/Qt-4.4.3/Qt-4.7
Tiny210Mother board
- Integrated USB 2.0 Hub: Extended 4 USB host ports, three of them as the standard side port,
and one was lead by SCON interface
- AV CCD Camera In: Integrated TVP5150 video chip: 2 AV input port (RCA), can be directly
connected using a CCD camera
- RS485: 1 RS485 interface
- Serial Port: 4 serial port, two of them have been converted to RS232, and leads through the
DB9 Block (COM0, COM1), through the CON1, 2, 3, 4, Block leads to TTL level
- keys: 8 key
- RJ45 Ethernet port: using DM9000AEP, 10/100M adaptive
- Audio input and output: using the WM8960 professional audio chip, containing Class D
amplifier on-board microphone, and supports HDMI audio and video synchronization output
- USB Slave: 1 Road, the USB 2.0 specification
- Infrared receiver: 1
- ADC input: 6 ADC input
- Buzzer: 1, control by the PWM0
- EEPROM:AT24C08 (256 Byte) for I2C test
- LCD Interface: 2 LCD interface, both 40 Pin 0.5mm Pitch Chip Block, support 3.5 "-19" full
color TFT display LCD
- SDIO interface: used to connect the SDWiFi module and other
- CMOS Camera interface: used to connect CMOS camera
- RTC clock: with a backup battery (according to different regions or time periods, mailing may
remove the battery)
- PCB layer: 2
- PCB size: 180 x 130mm, can be easily fixed all kinds of LCD modules, especially the 7-inch
LCD module
- Power supply: DC-5V
