Dual-head Hot End
Do you feel the printed module with single color too drab? Want to print a module of colors? This Dual-head Hot End Extruder will help you start you colorful 3D Printing.
"What is better, a single head extruder or dual head extruder?" - a question we have been asked on several occassions. The difference is very simple, while a single head extruder only holds one color filament, the other (dual head extrusion) can have two colors of filament. So honestly we think a dual head extruder is a preffered choice if you wish to make multi-colored 3D prints, but as it costs several hundred dollars more it is up you to decide how important multi-colored prints are.
If you are planning to use a 3D printer for art installations or making components then perhaps a single head extruder will work just fine. On the other hand, if you wish to make product prototypes or models with extra detail then multi-colored prints do give many objects, therefore a dual head extruder would be the prefered option. The dual head extruder just gives you that extra possibility of creating prints with more detail than if you were to use a single head extruder, for us that is definitly worth the extra amount.
Product Introduction
Printing resolution 0.1mm
Molding form FDM
Material Metal
Nozzle temperature 180℃-240℃
Outline dimensions 100*65*72mm L/H/W)
Weight 240g
Input voltage default to 12V
Thermisto 100K 1% high-precision NTC Thermistor
Cartridge heater 12V 30W
Click here to buy Dual-head Hotend Extruder
