Hot End V2.0
The 2.0 version is a high performance hotend for use with RepRap and other 3D printers,making your printing even faster. The hot end comes completely assembled: wire it to your electronics and it is ready to print. It now includes an aluminum mount plate and aluminum heat sinks. The 2.0 also brings changes to the nozzle, heater block, and threaded extension with harder aluminum and revised thread profile for more reliable nozzle changes.
This product adopts Teflon and aluminum alloy heat radiator for heat dissipation and duralumin alloy nozzle. Its surface is covered with anodic oxide coating, which can resist oxidation corrosion and increase nozzle hardness. Since the heat-insulated pipe is designed with Teflon, the material will not soften easily, thus ensuring finer and more stable printing.
Product Introduction
Printing resolution 0.1mm
Molding form FDM
Material Metal
Nozzle diameter optional,0.3, 0.35, 0.4 , 0.5 optional
Nozzle temperature 180℃-240℃
Outline dimensions 66*70*40mm L/H/W)
Weight 120g
Input voltage default to 12V
Thermisto 100K 1% high-precision NTC Thermistor
Cartridge heater 12V 30W
