Arduino YUN
NB : In some countries, it is prohibited to sell WiFi enabled devices without government approval. While waiting for proper certification, some local distributors are disabling WiFi functionality. Check with your dealer before purchasing a Yún if you believe you may live in such a country.
AVR Arduino microcontroller
Microcontroller | ATmega32u4 |
Operating Voltage | 5V |
Input Voltage | 5V |
Digital I/O Pins | 20 |
PWM Channels | 7 |
Analog Input Channels | 12 |
DC Current per I/O Pin | 40 mA |
DC Current for 3.3V Pin | 50 mA |
Flash Memory | 32 KB (of which 4 KB used by bootloader) |
SRAM | 2.5 KB |
EEPROM | 1 KB |
Clock Speed | 16 MHz |
Linux microprocessor
Processor | Atheros AR9331 |
Architecture | MIPS @400MHz |
Operating Voltage | 3.3V |
Ethernet | IEEE 802.3 10/100Mbit/s |
WiFi | IEEE 802.11b/g/n |
USB Type-A | 2.0 Host/Device |
Card Reader | Micro-SD only |
RAM | 64 MB DDR2 |
Flash Memory | 16 MB |
PoE compatible 802.3af card support (see the note below)
Schematic
Schematic:File:Arduino-Yun-schematic.pdf
Click here to buy Arduino Yun
