Arduino Voice Recognition Module
Revision as of 02:01, 29 April 2014 by Admin (talk | contribs)
We've beening thinking about a module which helps to control other devices by voice and it will not cost too much. Finally we designed this module. Well, what can this module do? It can recognize as much as 15 voice instruction, which is suitable for most cases involving voice control.
Parameters
1、Voltage:4.5-5.5V
2、Current:<40mA
5、Size: 30mm x 47.5mm
Example 1
1. Recording We need to send serial command to this module. You may need a USB-TTL module to connect it with PC. Send command 0xaa11 to record. Please refer to the manual for more information.
Please record the following voice instrctions in order :
1、WHITE 2、RED 3、GREEN 4、BLUE 5、OFF
2. Hardware connection
