Crazyflie
Revision as of 01:59, 20 November 2013 by Admin (talk | contribs)
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter
3 Start to flying
  • Start up the application
  • Press Connect
