Update firmware
Revision as of 08:14, 13 November 2013 by Admin (talk | contribs) (Created page with "For updating the Crazyflie firmware there's the possibility to enter bootloader mode and flash new firmware from within the client. The bootloader mode is accessed from the me...")
For updating the Crazyflie firmware there's the possibility to enter bootloader mode and flash new firmware from within the client. The bootloader mode is accessed from the menu Crazyflie→Bootloader. To update the firmware in the Crazyflie do the following: Make sure that the Crazyflie is disconnected from the client and powered off Go to the menu Crazyflie→Bootloader Click “Initiate bootloader cold boot” Power on the Crazyflie within 5 seconds using the battery (not USB), the booloader should now connect Press “Browse” and select the binary you want to download (e.g. cflie.bin) Press “Program” and wait Press “Restart in firmware mode” To check the firmware version, under the View menu, open up Tabs→Console tab and look at the output when connecting to the Crazyflie.
