Teensylu
Revision as of 08:02, 3 April 2013 by Admin (talk | contribs)
  • Small design - board is 100mm x 60mm
  • Teensylu clone, Atmel's AT90USB1286
  • Up to 4 A4988/4983 stepstick or Pololu stepper driver boards on-board (X,Y,Z,Extruder)
  • Supports multiple power configurations (Carried from Sanguinololu)
    • Logic & Motors supplied by ATX power supply (needs molex harddrive connector, and optional 4pin atx connector for additional 12v)
    • Motors supplied by 5mm screw terminal 7-35V
    • Logic supplied by USB bus
    • Logic supplied by optional on-board voltage regulator (molex harddrive connector cannot be installed at the same time)
    • on-board USB connectivity
  • 2 N-MOSFETs for extruder/bed heaters
  • 1 N-MOSFET for low power fan or motor
  • Selectable 12v/5v endstop voltage
    • 4 endstops including 4th stop called E-Stop to be used as an emergency stop, or extruder stop (to be added in firmware).
  • 14 Extra pins available for expansion and development - 6 analog and 8 digital (Fully compatabile with Sanguinololu), with the following capabilities
    • UART1 (RX and TX)
    • I2C (SDA and SCL)
    • SPI (MOSI, MISO, SCK)
    • PWM pin (1)
    • Analog I/O (6)
  • Additional 14 pin header with 11 I/O for prototyping
  • SMT Components sized at 0805 for easier soldering.
Compatible Firmwares
  • Sprinter
  • Marlin
  • Repetier
Building and Programming the Firmware (applying to the AT90USB1286 preinstalled the LUFA HID bootloader)
install. Be sure to select "all" when asked which additional libraries to install
  • Replace the avrdude.exe located in arduino-0023\hardware\tools\avr\bin with this version
avrdude() and better backup the original avrdude.exe which has been replaced, otherwise
uploading error will appear.If you have installed the Teensyduino library in Arduino 1.0 or
higher version, skip this step
  • Add the following to arduino-xx/hardware/teensy/boards.txt file at the bottom:
cdcteensylu.name=[BootloaderCDC]Teensylu/Printrboard
cdcteensylu.upload.protocol=avr109
cdcteensylu.upload.maximum_size=130048
cdcteensylu.build.mcu=at90usb1286
cdcteensylu.build.f_cpu=16000000L
cdcteensylu.build.core=teensy
cdcteensylu.build.define0=-DUSB_SERIAL
cdcteensylu.build.define1=-DLAYOUT_US_ENGLISH
cdcteensylu.upload.speed=115200
  • Download Sprinter firmware. https://github.com/kliment/Sprinter
  • Open Sprinter in arduino and configure configuration.h file.
  • Motherboard should be set to 8: #define MOTHERBOARD 8
  • Turn off endstops if you didn't install endstops: const bool ENDSTOPS_INVERTING = true;
  • Turn comment out SD card support, not working yet: //#define SDSUPPORT
  • Remove the HWB jumper on the board to boot into the bootloader.
  • Connect the USB cable to Teensylu, the virtual serial port appears. Remember this Serial port
number, because this port is for only for communication, not for programming.
  • Push the Reset button, the serial port number changes. This serial port is what we want for
programming the firmware.
  • Select the board Teensylu/Printrboard and uploding your firmware.
Sprinter(compatible for Arduino 023)
  • Download the arduino environment and install. http://arduino.cc/en/Main/Software
  • Download the Teensyduino library from pjrc and install. Be sure to select "all" when asked which additional libraries to install
  • Go to Tools menu and set Board to Teensy++ 2.0, or Teensylu if using alternate bootloader
  • Go to Sketch menu and click "Verify/Compile"
  • A program will popup for the teensy programmer after sprinter is done compiling
  • open the HEX File in teensy loader and move sprinter.cpp.hex to root folder of C drive for programming
Windows
  • Remove the HWB jumper beside the chip.
  • Press the rest button to start the bootloader.
  • Windows will find the new hardware as the virtual com port. If windows find the unrecognized hardware, install the USB Serial driver
  • Install the WinAVR
  • Run the cmd.exe in windows, input the command line
  • After flashing the firmware, replace the HWB jumper and push the reset button to run the firmware.
Schematics
Teensylu
Burn the bootloader
Lincomatic's blog
Click here to buy Teensylu
