Teensylu
  • Small design - board is 100mm x 60mm
  • Teensylu clone, Atmel's AT90USB1286
  • Up to 4 A4988/4983 stepstick or Pololu stepper driver boards on-board (X,Y,Z,Extruder)
  • Supports multiple power configurations (Carried from Sanguinololu)
    • Logic & Motors supplied by ATX power supply (needs molex harddrive connector, and optional 4pin atx connector for additional 12v)
    • Motors supplied by 5mm screw terminal 7-35V
    • Logic supplied by USB bus
    • Logic supplied by optional on-board voltage regulator (molex harddrive connector cannot be installed at the same time)
    • on-board USB connectivity
  • 2 N-MOSFETs for extruder/bed heaters
  • 1 N-MOSFET for low power fan or motor
  • Selectable 12v/5v endstop voltage
    • 4 endstops including 4th stop called E-Stop to be used as an emergency stop, or extruder stop (to be added in firmware).
  • 14 Extra pins available for expansion and development - 6 analog and 8 digital (Fully compatabile with Sanguinololu), with the following capabilities
    • UART1 (RX and TX)
    • I2C (SDA and SCL)
    • SPI (MOSI, MISO, SCK)
    • PWM pin (1)
    • Analog I/O (6)
  • Additional 14 pin header with 11 I/O for prototyping
  • SMT Components sized at 0805 for easier soldering.
Compatible Firmwares
  • Sprinter
  • Marlin
  • Repetier
Building Firmware
Sprinter(compatible for Arduino 023)
==Download the arduino environment and install. http://arduino.cc/en/Main/Software
==Download the [Teensyduino library http://pjrc.com/teensy/td_download.html] from pjrc and install. Be sure to select "all" when asked which additional libraries to install ==Download Sprinter firmware. https://github.com/kliment/Sprinter ==Open Sprinter in arduino and configure configuration.h file. ===Motherboard should be set to 8: #define MOTHERBOARD 8 ===Turn off endstops if you didn't install endstops: const bool ENDSTOPS_INVERTING = true; ===Turn comment out SD card support, not working yet: //#define SDSUPPORT ==Go to Tools menu and set Board to Teensy++ 2.0, or Teensylu if using alternate bootloader ==Go to Sketch menu and click "Verify/Compile" ==A program will popup for the teensy programmer after sprinter is done compiling ==open the HEX File in teensy loader and move sprinter.cpp.hex to root folder of C drive for programming
Programming the Firmware
Windows
  • Remove the HWB jumper beside the chip.
  • Press the rest button to start the bootloader.
  • Windows will find the new hardware as the virtual com port. If windows find the unrecognized hardware, install the [USB Serial driver http://pjrc.com/teensy/serial_install.exe
  • Install the [WinAVR http://winavr.sourceforge.net/]
  • Run the cmd.exe in windows, input the command line
  • After flashing the firmware, replace the HWB jumper and push the reset button to run the firmware.
Schematics
[Teensylu https://github.com/StephS/Teensylu]
Burn the bootloader
Lincomatic's blog http://blog.lincomatic.com/?p=548
Click here to buy Teensylu
