About Mini6410 Development Board
Revision as of 03:59, 27 June 2012 by Admin (talk | contribs) (Created page with "==Overview== The Mini6410 Single Board Computer is a high-performance controller board introduced. It is designed based on the S3C6410 microcontroller, 256MByte DDR SDRAM, 1GB...")
The Mini6410 Single Board Computer is a high-performance controller board introduced. It is designed based on the S3C6410 microcontroller, 256MByte DDR SDRAM, 1GByte Nand Flash, RTC, Audio and net on board. It has integrated RS232, USB, Ethernet, Audio In/Out, Keyboard, LCD, CVBS、TV out, camera in, SD card and more other functions on board. So many hardware resources provided by the expansion board, it becomes a solid reference board for customer design.
We also offers a complete software development package to customers. The board supports linux 2.6.36, Android2.1 and WindowsCE 6.0 operating system and is provided with complete basic drivers which enable a quick channel to evaluate the Samsung S3C6410 processor and customize application software. It would be an ideal development platform for multimedia and communication applications.
Hardware Features
The S3C6410X is a 16/32-bit RISC microprocessor, which is designed to provide a cost- effective, low-power capabilities, high performance Application Processor solution for mobile phones and general applications. To provide optimized H/W performance for the 2.5G & 3G communication services, the S3C6410X adopts 64/32-bit internal bus architecture. It also includes many powerful hardware accelerators for tasks such as motion video processing, audio processing, 2D graphics, display manipulation and scaling. An integrated Multi Format Codec (MFC) supports encoding and decoding of MPEG4/H.263/H.264 and decoding of VC1.
The Mini6410 Single Board Computer is based on S3C6410 processor. This board is characterized as follows:
  • Dimension: 110 x 110 mm
  • CPU: 533 MHz Samsung S3C6410A ARM1176JZF-S with VFP-Unit and Jazelle (max freq.
 667 MHz)
  • RAM: 256 MB DDR RAM, 32 bit Bus
  • Flash: 256MB NAND Flash(can support 1GB nand flash)
  • EEPROM: 1024 Byte (I2C)
  • Ext. Memory: SD-Card socket
  • Serial Ports: 1x DB9 connector (RS232), total: 4x serial port connectors
  • IR: Infrared Receiver
  • USB: 1x USB-A Host, 1x miniUSB Slave-OTG 2.0
  • Audio Output: 3.5 mm stereo jack
  • Audio Input: Condenser microphone
  • Ethernet: RJ-45 10/100M (DM9000)
  • RTC: Real Time Clock with battery
  • Beeper: PWM buzzer
  • Camera: 20 pin Camera interface (2.0 mm)
  • TV Output: CVBS
  • LCD Interface
        **STN Displays:
                *** Monochrome, 4 gray levels, 16 gray levels, 256 colors, 4096 colors
                *** Max: 1024x768
        **TFT Displays:
                *** Monochrome, 4 gray levels, 16 gray levels, 256 colors, 64k colors, true
                   color
                *** Max: 1024x768
        **40 pin (2.0 mm) and 41 pin connector for FriendlyARM Displays (4.3" and 7")
  • Touch Panel: 4 wire resistive
  • User Inputs: 8x push buttons and 1x A/D pot
  • User Outputs: 4x LEDs
  • Expansion: 40 pin System Bus, 30 pin GPIO, 20 pin SDIO (SD, SPI, I2C), 10 pin Buttons (2.0 mm)
  • Debug: 10 pin JTAG (2.0 mm)
  • Power: 5V connector, power switch and LED
  • Power Supply: regulated 5V (Mini6410: 0.25 A, Mini6410 + 4.3" LCD: 0.5 A)
  • OS Support
        **Windows CE 6
        **Linux 2.6
        **Android
        **Ubuntu
