Arduino Digital Vibration Sensor module
Revision as of 09:54, 14 May 2012 by Admin (talk | contribs)
introduction
The Arduino vibration sensor module is based on vibration switch component which can detect the weak vibration signals. The sensor can work for vibration-related modules.
Product Performance:
  • The conductive pin will make an instant turn-on (ON) state when touched by the outside force to achieve the proper vibration force, or an appropriate speed from the (partial) energy.
  • No direction, any angle may burst.
  • The switch is suitable for small-current circuit (secondary circuit) or (IC) of the trigger.
  • At room temperature and normal use the next switch service life is up to 10 million times (times/1sec).
On-Time: 0.1ms
Open circuit resistance: 10Mohm
Pin definition
VCC - 5V
GND - GND
S   - Digital pin3
int ledPin = 13;                // Connect LED to pin 13
int switcher = 3;                 // Connect Tilt sensor to Pin3
 pinMode(ledPin, OUTPUT);      // Set digital pin 13 to output mode
 pinMode(switcher, INPUT);       // Set digital pin 3 to input mode
  if(digitalRead(switcher)==HIGH) //Read sensor value
       digitalWrite(ledPin, HIGH);   // Turn on LED when the sensor is tilted
       delay(300);
  else
       digitalWrite(ledPin, LOW);    // Turn off LED when the sensor is not triggered
How to buy it
Click here to buy vibration sensor
