Arduino Digital Vibration Sensor module
Revision as of 09:52, 14 May 2012 by Admin (talk | contribs) (Created page with "==introduction== File:Vibration sensor.jpg The Arduino vibration sensor module is based on vibration switch component which can detect the weak vibration signals. The sen...")
introduction
The Arduino vibration sensor module is based on vibration switch component which can detect the weak vibration signals. The sensor can work for vibration-related modules.
Product Performance:
The conductive pin will make an instant turn-on (ON) state when touched by the outside force to achieve the proper vibration force, or an appropriate speed from the (partial) energy. No direction, any angle may burst. The switch is suitable for small-current circuit (secondary circuit) or (IC) of the trigger. At room temperature and normal use the next switch service life is up to 10 million times (times/1sec).
On-Time: 0.1ms Open circuit resistance: 10Mohm
VCC - 5V
GND - GND
S   - Digital pin3
int ledPin = 13;                // Connect LED to pin 13
int switcher = 3;                 // Connect Tilt sensor to Pin3
 pinMode(ledPin, OUTPUT);      // Set digital pin 13 to output mode
 pinMode(switcher, INPUT);       // Set digital pin 3 to input mode
  if(digitalRead(switcher)==HIGH) //Read sensor value
       digitalWrite(ledPin, HIGH);   // Turn on LED when the sensor is tilted
       delay(300);
  else
       digitalWrite(ledPin, LOW);    // Turn off LED when the sensor is not triggered
How to buy it
Click here to buy [vibration sensor]
