3.2TFT LCD
Revision as of 00:45, 14 May 2012 by Admin (talk | contribs) (Display:)
introduction
HY-TFT320 is a 3.2 inch TFT LCD Screen module, 320*240 (resolution), 65K color, 40pins interface , not just a LCD breakout, but include the Touch screen, SD card. So it’s a powerful extension module for your project.
Application Ideas
  • Digital Photo Frame (DPF)
  • Video terminals
  • Instrumentation
  • GPS
  • Game consoles
Specification:
  • 3.2" Color TFT LCD
  • 320 x 240 Resolution
  • 65,536 Colors (16 Bit)
  • Built-in video RAM buffer
  • Integrated SD card
  • 5V Operating Voltage
  • LED Backlight
pin difinition
Usage:
Display:
[The TFT library http://www.henningkarlsen.com/electronics/library.php?id=39] is required to be installed to get this screen model display. This library is especially designed for 3.2” TFT LCD screen using 16 bit mode. The library require the following connections.
  • Connect HY-TFT320 to Arduino Mega2560:
LEDA -> 5V
VCC -> 5V
RD -> 3.3V
GND -> GND
DB0->DB7 to pin D37->D30
DB8->DB15 to pin D22->D29
RS -> D38
WR -> D39
CS(pin6) -> D40
RSET-> D41
  • Connect HY-TFT320 to Arduino UNO
LEDA -> 5V
VCC -> 5V
RD -> 3.3V
GND -> GND
DB0->DB5 to D8->D13
DB6->A0
DB7->A1
DB8->DB15 to D0->D7
RSET->A2
CS->A3
WR->A4
RS->A5
Touch Screen:
The LCD has a 3.2" 4-wire resistive touch screen lying over it. The Touch library needs to be installed to get it works. This library is designed for 2.4’’ TFT, 3.2” TFT LCD screen module.
DCLK-> D6
CS(pin30) -> D5
IN -> D4
OUT-> D3
IRQ -> D2
SD Card:
SCK -> D52
MISO -> D50
MOSI-> D51
CS -> D53
How to buy it
Click here to buy 3.2“TFT LCD
