Arduino Analog Temperature Sensor Module
Revision as of 02:28, 11 May 2012 by Admin (talk | contribs) (Created page with "==Introduction== File:Thmistor module.jpg Our analog Temperature Sensor Based on thermistor - a resistor that changes its resistance with temperature.This Temperature Sen...")
Our analog Temperature Sensor Based on thermistor - a resistor that changes its resistance with temperature.This Temperature Sensor Module measures the environment temperature and input data to Arduino through the analog I/O port of Sensor Shield. Great tool for gardening projects, home alert system etc.
Building interactive work is as easy as piling bricks, just plug it to our Arduino Sensor Shield with a buckled cable, and make it looks professional and neat.A simple program below converts data from Temperature Sensor Module to Celcius and displays it in Serial Monitor. This function utilizes the Steinhart-Hart Thermistor Equation to convert "Thermistor Resistance" to "Temperature in Degrees Kelvin."
File:Thmistor module wiring.jpg
#include <math.h>
double Thermister(int RawADC) {
double Temp;
Temp = log(((10240000/RawADC) - 10000));
Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
Temp = Temp - 273.15;            // Convert Kelvin to Celcius
return Temp;
void setup() {
void loop() {
Serial.print(Thermister(analogRead(0)));  // display Fahrenheit
Serial.println("c");
delay(500);
How to buy it
Click here to buy Arduino Analog Temperature Sensor Module
