LM35 Analog Temperature Sensor Module
Revision as of 09:24, 10 May 2012 by Admin (talk | contribs) (Created page with "==Introduction== File:LM-35.jpg The Arduino LM35 Linear Temperature Sensor module is based on the semiconductor LM35 temperature sensor. The LM35 Linear Temperature Se...")
semiconductor LM35 temperature sensor. The LM35 Linear Temperature Sensor
module can be used to detect ambient air temperature. This sensor is
produced by National Semiconductor Corporation and offers a functional
range between -40 degree Celsius to 150 degree Celsius. Sensitivity is
10mV per degree Celsius. The output voltage is proportional to the
temperature.
It is commonly used as a temperature measurement sensors. It includes
thermocouples, platinum resistance, thermal resistance and temperature
semiconductor chips, which commonly used in high temperature measurement
thermocouples. Platinum resistance temperature used in the measurement of
800 degrees Celsius, while the thermal resistance and semiconductor
temperature sensor suitable for measuring the temperature of 100-200
degrees or below, in which the application of a simple semiconductor
temperature sensor has good linearity and high sensitivity. The LM35
linear temperature sensor and sensor-specific expansion of Arduino board,
in combination, can be very easy to achieve
  • Based on the semiconductor LM35 temperature sensor
  • Can be used to detect ambient air temperature
  • Type: Analog
  • Sensitivity: 10mV per degree Celcius
  • Functional range: -40 degree Celsius to 150 degree Celsius
int potPin = 0;
float temperature = 0;
long val=0;
void loop ()
   val=analogRead(potPin);
   temperature = (val*0.0048828125*100);
   Serial.print("Tep=  ");
   Serial.print(temperature);
   Serial.println(" C");
   delay(500);
Click here to buy
