DS18B20 Temperature Sensor Module
Revision as of 02:21, 9 May 2012 by Admin (talk | contribs) (Created page with "==introduction== This breakout uses the DS18B20 1-Wire digital temperature sensor from Maxim IC. It can Reports degrees C with 9 to 12-bit precision, -55C to 125C (+/-0.5C). E...")
introduction
This breakout uses the DS18B20 1-Wire digital temperature sensor from Maxim IC. It can Reports degrees C with 9 to 12-bit precision, -55C to 125C (+/-0.5C). Each
sensor has a unique 64-Bit Serial number etched into it - allows for a huge number of sensors to be used on one data bus. This is a wonderful part that is the corner
stone of many data-logging and temperature control projects.
  • 3.0-5.5V input voltage
  • Waterproof
  • -55°C to+125°C temperature range
  • ±0.5°C accuracy from -10°C to +85°C
  • 1 Wire interface
#include <DallasTemperature.h>
DallasTemperature tempSensor; // You may instantiate as many copies as you require.
void setup(void) {
 tempSensor.begin(12); // Data wire is plugged into port 12 on the Arduino
 Serial.println("Dallas Temperature IC Control Library 1.0. Miles Burton");
void loop(void) {
   // Ask the library whether the device is valid
   switch(tempSensor.isValid())
       case 1:
           Serial.println("Invalid CRC");
tempSensor.reset(); // Attempts to redetect IC return;
       case 2:
           Serial.println("Not a valid device");
      return;
 Serial.print(tempSensor.getTemperature());
 Serial.print("C");
 Serial.println();
 Serial.print(DallasTemperature::toFahrenheit(tempSensor.getTemperature()));   Serial.print("F");
 Serial.println();
how to buy
Click here to buy DS18B20 Temperature Sensor Module
