Geeetech Mizar S 3D Printer
Revision as of 06:53, 13 June 2023 by Admin (talk | contribs)
Printer Introduction
Main Specification
Printer Type FDM
Layer Thickness 0.1-0.3 mm
Auto-leveling Yes
Break Resuming Yes
Preheat time(110℃) 7 min
Nozzle Diameter 0.4 mm
Printing Accuracy ±0.1 mm
Supported File Format .gcode
Hotbed Max. Temperature 110 ℃
Printing Size 255*255*260 mm
Net Weight(kg) 8.9 kg
Gross Weight(kg) 11.2 kg
How to replace PSU
Allen keys - 2.5/3 mm
Assembling the new PSU.
Tighten the two screws.
How to replace a hotend
Wrench size 10 mm
Allen keys – 1.5/2/2.5/3 mm
Diagonal pliers
Electrical tape
Zip ties
Craft knife or equivalent
Step 1 Preparing
Remove the strain gauge.
Fix the new strain gauge.
Install the new hotend.
Step 5 Install the PTFE tube
How to replace a hotbed
Allen keys – 3 mm
Diagonal pilers
Zip ties
Tighten the three screws.
How to replace a screen
Connect the LCD cable.
How to replace a filament sensor
Allen keys – 2.5/3 mm
Disconnecting all the cables.
Tweezers for nozzle
Wrench size 6/10/20 mm
Needle for nozzle
Allen key - 2 mm
Step 1 Clean the hotend
Step 2 Replace a nozzle
Turn the printer off.
Black screen
Mintemp Error
How to update:
4.Update is complete.
Notice:
Automatic leveling failed
(a)Nozzle calibration failed
(b)Homing failed
(c)The first layer is messy
Material break detection wear
Please add a section of pipe in front of the filament sensor to prevent wearing.
Consumables stick to the hot bed
The consumables don't fall off the Mylar
Filament residues stick to Mylar sheets and are difficult to remove, usually because the nozzle is too close to the hot bed when printing the first layer, resulting in very thin extruded filaments. You need to readjust the Z-offset. Please preheat the hot bed to above 80 degrees, then wipe the remaining filaments with a damp cloth, and gently scrape them off with a spatula.
The printer cannot be turned on after assembly
1.Please make sure you select the correct voltage first.
2. Check that the motherboard is properly connected to the screen, as shown in Figure 1. Switch the mains on and the screen works as shown in Figure 2.
3. The power supply is working normally as shown in Figure 3.
4. Check whether the mainboard works properly, as shown in Figure 4.
The thickness of the first layer printed is uneven
