Geeetech Mizar S 3D Printer
Revision as of 10:12, 9 June 2023 by Admin (talk | contribs)
Main Specification
Printer Type FDM
Layer Thickness 0.1-0.3 mm
Auto-leveling Yes
Break Resuming Yes
Preheat time(110℃) 7 min
Nozzle Diameter 0.4 mm
Printing Accuracy ±0.1 mm
Supported File Format .gcode
Hotbed Max. Temperature 110 ℃
Printing Size 255*255*260 mm
Net Weight(kg) 8.9 kg
Gross Weight(kg) 11.2 kg
Printer maintenance
How to replace a hotend
Wrench size 10 mm
Allen keys – 1.5/2/2.5/3 mm
Diagonal pliers
Electrical tape
Zip ties
Craft knife or equivalent
Step 1 Preparing
Remove the strain gauge.
Fix the new strain gauge.
Install the new hotend.
Step 5 Install the PTFE tube
How to replace PSU
Allen keys - 2.5/3 mm
Assembling the new PSU.
Tighten the two screws.
How to replace a hotbed
Allen keys – 3 mm
Diagonal pilers
Zip ties
Tighten the three screws.
How to replace a screen
Connect the LCD cable.
How to replace a filament sensor
Allen keys – 2.5/3 mm
Disconnecting all the cables.
Tweezers for nozzle
Wrench size 6/10/20 mm
Needle for nozzle
Allen key - 2 mm
Step 1 Clean the hotend
Step 2 Replace a nozzle
Turn the printer off.
Tweezers for nozzle
Needle for nozzle
Allen key - 2 mm
Trouble shooting
Black screen
Mintemp Error
How to update:
4.Update is complete.
Notice:
Automatic leveling failed
(a)Nozzle calibration failed
(b)Homing failed
(c)The first layer is messy
Consumables stick to the hot bed
